Your advice was partly correct and partly wrong:
DYNMODE (0 or 1) turns Dynamic Input on or off and can be controlled with one of the tiny buttons on the bottom of your screen. This is your problem fixed and was probably caused in the first place by a careless click.
If DYNMODE is Off(0) then the value of DYNPICOORDS is irrelevant.
Blindly changing Setvars is not a good idea.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
