734 Vistas, 9 Respuestas
Prabolic Duct in Rectangular Block
Hello All,
I am trying to model a rectangular 3D slab with size 4.3mX1.6mX0.16m with a duct of 15.7mm.
The duct should start from center at one end and then should go parabolically to the other end ending again at center. the maximum depth of duct should be 50mm .
How can i do that?
Kent1Cooper
en respuesta a: Anonymous
I'm having a hard time imagining what you're describing.  An image [even a scan of a hand sketch] would be very helpful.
Kent Cooper, AIA
en respuesta a: Kent1Cooper
hi,I am Attaching a sketch of it. I need a rectangular slab with a duct in between which is parabolic in nature.(the duct varies parabolically)
Thanks in Advance Regards,Prashant MotwaniResearch Scholar, Civil Engineering Dept.Indian Institute of Technology(IIT), BombayContact: +91-9981135555Email: 164040005@iitb.ac.in, motwaniiitb@gmail.com
Kent1Cooper
[nothing attached....]
Kent Cooper, AIA
Sorry for that. PFA
imadHabash
Sweep command will serve you.
A sample.dwg attached..
Imad Habash
en respuesta a: imadHabash
Are you modeling tension rods in the slab?
no i need to model postension strand in the parabolic duct.I am going to export the slab in ABAQUS and do its Finite Element Analysis. Can You help in modeling ?
SEANT61
I guess the remaining concern would be the Parabola.  That can be made using a degree 2 spline.
I'm not sure about all the dimensions, specifically the duct dia.(15.7 ?), or what the 0.05 M drop refers to (duct wall), but the attached is my interpretation.
May your cursor always snap to the location intended.
SEANT61
en respuesta a: SEANT61
This screencast demonstrates the viability of a degree 2 spline as a parabola:
