Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
By the time I specify base point the image gets zoomed and moves away from its original position ...,and also I can't find the command for reference ....
The "zooming/moving" is probably the dynamic dragging of the scale result, using the distance in drawing units from your base point to the current cursor location as the scale factor.  Depending on your units and the size of your image, that can mean an immediate huge over-scaling of the image, but it's only in dynamic display of what the result will be if you pick at the current cursor location -- it hasn't changed anything about the image yet.  If you set the DRAGMODE System Variable to anything other than Auto [either Off entirely, or "merely" On, which will let you call for dragging by typing DRAG when it's asking for a scale factor, but won't drag the scale unless you ask for it], then it won't do that.
Reference is not a command, but an option within the Scale command [and also within Rotate], offered after you have given it a base point.
Kent Cooper, AIA
