imadHabash
en respuesta a: Anonymous
Hi and welcome to AutoDesk community,
it's highly appreciated if you give us more clear details regarding:
- you wrote (.. I specify base point the image..) why and how did you do that?
- you wrote ( .. and also I can't find the command for reference so that I can trace the ..) referance to what and with which command?
because scale already have Reference option .
Command: SCALE
Select objects: 1 found
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]
- you wrote ( ..the only command that pops up is "redraw"..) pop up with which command and when ?
Imad Habash
