GrantsPirate
en respuesta a: Anonymous
I looked at the link you provided.  The next step is to draw a curve on the outline of the objects you have shown, just look at their next example as to what you should end up with.  Use the pline command or spline command and set endpoint osnap on and pick on the ends of the lines inside the circle, use intersection osnap for the intersections outside the circle.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
