546 Vistas, 1 Respuesta
Command Syncing text and lines
Is there a command that will sync with the attribute text with a line or polyline.
Example:
I have an attribute text of "FLOOR PLAN", the below it has a line/polyline with a length more than a bit of the "floor plan" text.
Once I make this a block, it will an enhanced attribute editor right.
So, is there a command for it if I will change "FLOOR PLAN" to "SITE DEVELOPMENT PLAN" the line/polyline below automatically extends with the same length added from "FLOOR PLAN" to "SITE DEVELOPMENT PLAN"?
Please share, thanks!
GrantsPirate
en respuesta a: Anonymous
Why not use the underline codes for that?
%%u FLOOR PLAN %%u
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
