- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have AUTOCAD LT 2016.
When I try to draw multi text is said unknown command.
Can someone please help.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi and Welcome to AutoDesk Forum,
i suggest to get MT mtext working is to try the follow :
- use REDIFINE command
Command: REDEFINE
Enter command name: mtext
- if previous step doesn't work try to paste (arxload "ACMTED") in the command line.
Hope it's help..
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i found my own answer.
Solution
To resolve this problem:
On the Tools menu, click Options.
In the Options dialog box, click the Open and Save tab.
Under ObjectARX Applications, select Command Invoke from the Demand load ObjectARX Apps list.
If this setting is set to either Disable load on demand or Custom object detect, these AutoCAD commands do not work.
This issue can also affect commands in AutoCAD based software products.
