en respuesta a:
10:48 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-10-2017
10:48 AM
If you use inches in your drawing simply scale with a factor of 25.4 (25 is accepted sometimes as it gives you rounded up numbers).
use UNITS command and change Inches to mm (unitless will do the same)
use SCALELISTEDIT and click RESET, choose METRIC SCALES, if 1:30 is not in the list click ADD.
That should help you through it.
