pendean
en respuesta a: nrz13
These are all separate DLL files inside separate version-specific folders, but if you want to believe this is the reason I'm not going to argue about it :cara_con_una_leve_sonrisa:
We've probably discussed it before too, but relying on automatic migrations can sometime be a problem although it isn't for most.
Feel free to offer the OP real advise on a fix if you have one. Just make sure the real culprit isn't 2016's install of Directx11 when your PC/Vid Card can only function best under Directx9.
