- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Not Responding When Using Text Edit
I have a job that whenever i use text edit autocad crashes for 1-3 mins (not responding) if properties pallatte is showing. I turn the pallatte off, but then it pops up again as im working as it is used often and inevitably it happens again. Any solutions ?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Windows 7 - Autocad 14, . If the properties window is closed text edit is a little slow but works, if open I get the, not responding sometimes for 3-4 minutes before it opens the text box.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is it a standard font/textstyle, or a custom font? Is the font accessed from a network location or stored on your local hard disk? Does the problem occur in other drawings using the same font... does it occur in the same or other drawings using a different font?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It is a standard text used every day on most jobs on a local office drive. The problem is specific to this job file , some others in the office have the same problem with this drawing and some do not , but not everyone is on running on 2014.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Way quicker than any thing attempts at fixing the file without sharing it here for everyone to try.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
copy a new text and retype annotation. Delete the text you are trying to edit (there is error in that)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As a test, make a copy of the file and remove everything from the file except one of the troublesome texts. Does the problem still occur with the Properties palette open?
If so, can you share that edited file here?
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
