edwin.prakoso
en respuesta a: Anonymous
Try to download this registry key. Rename the file from acad2016.txt to acad2016.reg.
I can't upload the file as registry file because it's not permitted here. You need to rename it first.
After you rename it, just double click it to change the registry value.
I export only the required value to update your registry, so it will not affect other software.
Note: this registry key will work only if you install AutoCAD in C:\Program Files\Autodesk\AutoCAD 2016
Cheers,
Edwin Prakoso
