- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Try a repair on AutoCAD 2016 see if that works. You will need to open a drawing firstly of course in 2016 to reassociate. If that doesnt work, take a look at the link i sent you before. Open AutoCAD 2016 and hopefully it rewrites those registry settings to open the last know product used for DWG format.
You could also look at turning Automatic Association back on in the registry... To Turn on automatic association in ACAD there is a registry key called DwgAlwaysAssociate in HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.1\ACAD-F001:409\Profiles\<<Unnamed Profile>>\General\ set it to 1.
Also take a look at this useful link which explains what you can do in the registry... https://designandmotion.net/autodesk/mfg-pages/inventor/autodesk-dwg-launcher-wigged-out-fix/
You could always just set the dWG format to the AutoCAD 2016 acad.exe rather than DWG LAuncher.
