33134 Vistas, 24 Respuestas
AutoCAD 2016 will not open when .dwg file is double-clicked
I am using Windows 7 professional.  I removed all my previous versions of Autocad using the windows add/remove program . I then downloaded and installed Autocad 2016. I can open drawings from within autocad or by dragging the file to the Autocad shortcut on the desktop. If I try to open a drawing by double clicking or a right click and select open like I could in previous versions, I get an error message that it cannot find the autocad 2015 exe. Dwd Launcher is set as the default to open the program. I tried a repair and a reinstall.  When I go into the registry, I see autocad 2015 not 2016. I suspect that this is the problem but I am not knowledgeable enough to try and edit the registry. I am attaching images of the error., the default program and the registry. Allan Daschuk
