12-10-2015
07:54 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-10-2015
07:54 AM
So I suspect the "other machine" user checked the box on that pop-up that says DO NOT SHOW THIS AGAIN, and probably also turned off PROXYNOTICE variable but turned on PROXYGRAPHICS and PROXYSHOW.
Either way though, on your PC or on others, if anyone in 2013 or higher version of AutoCAD open a 2010 or lower format DWG file with AEC content in it those objects will get upgraded and make editing those objects impossible for the owner of those AEC objects in their AEC capable software (not plain AutoCAD or LT).
BUT... I suspect, like 90% of users with this problem, you really don't know what these AEC objects are and don't need to care much about sending them back to the objects originator, so explode them in 2016 (AutoCAD or LT) with AECTOACAD command once and for all and move on with your CAD project.
If someone needs them, you'll know it soon enough, but since you upgraded them in 2016 they are already useless anyway.
Good luck.
Good luck.
