mwright1971
en respuesta a: pendean
OK I copied and pasted it into my command line and it came up "nil". I attached a screen shot so you can see it. Does that mean nothing is loaded? I went to the alias editor and scrolled through the list and the commands are coming up correctly, but functioning correctly. The alias editor shows that 'x' is for explode, but when I type it in to the command line, it comes up xclip. I also included 'b' becuase the command line comes up block editor (bedit) first instead of the block command. I attached 2 screen shots of the alias editor window.
I'm going to try overwrite the 'acad' files in the support folder with the ones my co-worker sent to me, maybe that might trigger a fix.
Thanks again Dean!
