pendean
en respuesta a: mwright1971
At the commandline, type this exactly as you see it (or copy/paste):
(startapp "notepad" (findfile "acad.pgp"))
This will open the correct PGP file that your session is using: examine it for errors. Remember to use REINIT command to reload that PGP after you edit it. Also remember, if you add your needed shortcuts at the bottom of the PGP file they overwrite the ones at the top of that file.
