1419 Vistas, 3 Respuestas
Troubleshooting Arc-Aligned Text
I've been having trouble with Arc-Aligned text. Whenever I open our file for a job these boxes appear (see Image attachment), I can quickly fix this problem by just using the Arc Aligned text tool again and just click on the circle and the boxes go away and the arc text comes back, however how can I just fix this permanetly? My coworker can open these files on his computer and he has no trouble. It does this through multiple files, even through Sheet Set Manager.
Etiquetas (2)
pendean
en respuesta a: Anonymous
That Express Tool must be loaded in an AutoCAD session for it's results to be seem: why your colleague doesn't have the issue and why it works after you launch the command manually.
Match the setting for DEMANDLOAD variable between the two AutoCAD stations and see if that helps.
wispoxy
It's a blank FIELD box.
en respuesta a: pendean
So far I haven't seen it happen so I believe your solution helped! Much appreciated!
