04-02-2015
11:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-02-2015
11:59 AM
one thing you coudl try is to reset your 2009 user profile to see if that resolves the issue.
- Navigate to: “C:\Users\\AppData\Local\Autodesk”
- For the Autodesk product with which you are having a problem, append the word “OLD” to that folder (For Land Desktop, I dont called how that folder was named. I assume it is something like LDC2009, LDT2009, or it might be Land Desktop 2009)
- Navigate to “C:\Users\\AppData\Roaming\Autodesk”
- For the Autodesk product with which you are having a problem, append the word “OLD” to that folder.
- Open Regedit and then navigate to HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\
- If you have more than one AutoCAD product, you’ll see a variety of Rxx.x numbers. These correspond to different AutoCAD releases, with the major number incrementing when a new DWG format is released. For 2009 Versions the number should beR17.2. For a specific list, see here: http://en.wikipedia.org/wiki/AutoCAD
- Now delete the R17.2 folder.
- Now launch Land Desktop 2009 and it will rebuild the Autodesk Windows Profile from default.
I have seen this resolve many issues, so it could be worth a try.
Jason Ferrelli
