1507 Vistas, 6 Respuestas
weld.lsp Will Not WORK ???
I have loaded the Welds LISP (with SBL and DCL) Chris Crain's automated weld symbol.
I moved the three files to where I keep all of my LSP commands and renamed them WELD.LSP, WELD.DCL & WELD.SLB.
Then on the cammand line in ACAD i entered APPLOAD and loaded the LSP,
Everytime I try to use the command "WELD" I get an Error stating: File Not Found WELD.DCL
Can ANYONE Help
Etiquetas (3)
Patchy
en respuesta a: Anonymous
It was posted as zip file and what is the reason you have to rename them?
en respuesta a: Patchy
The file names in the lisp code are called WELD.LSP, WELD.DCL & WELD.SLB. If I donot change the names I get the same errors. I have found the same code from multiple users and I get the same results.
Patchy
Try put all of them in SUPPORT Folder
Type in:
(findfile "support")
that is where you put all 3 of them.
Exit autocad and restart.
Jonathan3891
You need a support pointed to the location of the Weld.DCL
Jonathan Norton
Blog | Linkedin
May I know where I can get this weld lisp from?
ВeekeeCZ
On cadalyst...
http://cadtips.cadalyst.com/standard-blocks/automated-weld-symbols
