- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Selection Cycling Shift+Space not working in 2016
I just noticed that I cannot get shift+space to work for selection cycling. I prefer this method over the selection cycling box just because it is habit. I do have SELECTIONPREVIEW=3 and LEGACYCTRLPICK=2 as mentioned in previous posts for 2015 and it still will not work. It works for me in 2015, but when I installed 2015 I used a menu migrated from 2013 (which I think was migrated every year back to 2007). When I loaded 2016 I figured it was time to start from scratch, so I suspect that may have something to do with it.
To anyone out there with a non-migrated install of 2016, is shift+space working for selection cycling? I'm wondering if there is something in the cui that was previously migrated and is no longer there, but I haven't found it yet.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Shift + Space works here in 2016 on both migrated and non-migrated machines, both within a command*, and with no command active.
(SELECTIONPREVIEW=3 LEGACYCTRLPICK=2)
Do you have a specific procedure you're doing, or doesn't it work at all?
*edit. Shift + Space works within some commands.... there are instances where COMMANDPREVIEW interferes with Selection Cycling.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for mentioning that. It works with no command active but does not work in a command. What am I missing?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
COMMANDPREVIEW maybe? (It also interferes with "some" Selection Cycling operations in 2015.)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Update...it works in a command also, unless that command is Erase. If I type in Erase first, it will not work, but it works with copy, move, etc.
Does yours work if you type in Erase first? Maybe it has something to do with the new funky way that erase visually makes the object fade out first...
COOMANDPREVIEW is on.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Same here. I had never noticed it with ERASE command, but I have with FILLET, TRIM, EXTEND, etc. If the result of a command are currently being displayed as a "preview", then Shift + Space won't cycle.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The Shift-Space method only cycles once through the objects? Then I have to put the cursors away from the objects and put it back, then I´m able to cycle through again.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have run through every single variable, setting, etc. listed in all the posts for 2015 and 2016 and I have zero results. I can't cycle through anything at all. It only works periodically and when it breaks i jump to another session...if it doesn't work there i just work around it with some simple layer control and keep being productive. When I try to cycle it won't even select anything. It acts like my crosshairs and pickbox don't work or exist. Very strange and extremely annoying. I can get the other "visual" method to work but like the above poster my preference is to not slow down to have to pick something from a box. Just another one of those glitches to work around but any additional input would be great!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Resistance to change can bring about frustration. Sometimes you just have to accept and embrace new features. I was frustrated when selection cycling changed to Shift+Space. Never got used to that one. The new box is the bomb. Much easier, IMHO.
"Use the force, Luke."
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
