1967 Vistas, 7 Respuestas
problem downloading autocad 2016
hello people
I got a clase mate wich has problems downloading autocad 2016 from the site the download fie get's loaded and then he gest a download that i count download possible cause are the firewall or the location where its present or the site is bee reloaded before the download launcher could be loaded but the firewall and the location are checked and are good and the site refreshing is something wich i can't check, i hope some of you can  help us with a solution
Info system
win 7 64-bit home prenium
browser: google chrome
kind regards
Gjalt Kroonen
Etiquetas (3)
camilo.lemos
en respuesta a: Anonymous
Hi @Anonymous and welcome to the Autodesk Community!
I'm not sure I fully understand the issue. Any chance you could post the full content of the error message here (if you can post an image, that would be even better).
Thank you!
Camilo Lemos
Do share some Snap shots for better understnading..
pendean
If offered, use the DOWNLOAD MANAGER option instead of all the others: I had a similar issue last night and that was the only option that worked.
en respuesta a: pendean
where can i find that download manager????
never mind I alredy got it and its downloading
I can't seem to find the manager button you said that worked for you. Can you explain where i can find it?
en respuesta a: camilo.lemos
hey I am having the same issue of not being able to download from the website, here is the installation log and I have tried both Google Chrome and *sigh Internet explorer as well as firewall on and off nothing seems to work and I have a time sensitive matter.  Any assistance would be greatly appreciated
2016/9/14:17:04:39 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:04:39 dan DAN-PC Path_Length: 154
2016/9/14:17:04:39 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2016/9/14:17:04:39 dan DAN-PC Launch
2016/9/14:17:04:39 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2016/9/14:17:04:39 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AID5B6.tmp
2016/9/14:17:06:31 dan DAN-PC === Setup ended ===
2016/9/14:17:04:43 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:04:43 dan DAN-PC Path_Length: 154
2016/9/14:17:04:43 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AID5B6.tmp
2016/9/14:17:04:43 dan DAN-PC Launch
2016/9/14:17:05:18 dan DAN-PC Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2016/9/14:17:05:18 dan DAN-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2016/9/14:17:05:18 dan DAN-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2016/9/14:17:06:26 dan DAN-PC Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2016/9/14:17:06:26 dan DAN-PC Error downloading. Please Install Now again from the Autodesk website. 2016/9/14:17:06:32 dan DAN-PC === Setup ended ===
2016/9/14:17:07:16 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:07:16 dan DAN-PC Path_Length: 154
2016/9/14:17:07:16 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2016/9/14:17:07:16 dan DAN-PC Launch
2016/9/14:17:07:16 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2016/9/14:17:07:16 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI3BD8.tmp
2016/9/14:17:08:33 dan DAN-PC === Setup ended ===
2016/9/14:17:07:21 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:07:21 dan DAN-PC Path_Length: 154
2016/9/14:17:07:21 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI3BD8.tmp
2016/9/14:17:07:21 dan DAN-PC Launch
2016/9/14:17:07:22 dan DAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2016/9/14:17:07:22 dan DAN-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2016/9/14:17:08:33 dan DAN-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2016/9/14:17:08:33 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI3BD8.tmp\Setup\AcSetup.dll
2016/9/14:17:08:33 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:17:08:33 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:08:45 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:08:45 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:17:08:45 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:09:17 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:17:09:17 dan DAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2016/9/14:17:09:17 dan DAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2016/9/14:17:09:18 dan DAN-PC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2016/9/14:17:09:21 dan DAN-PC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2016/9/14:17:09:21 dan DAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\dan\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/9/14:17:10:25 dan DAN-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/9/14:17:10:25 dan DAN-PC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2016/9/14:17:10:31 dan DAN-PC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2016/9/14:17:10:31 dan DAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\dan\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/9/14:17:12:07 dan DAN-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/9/14:17:12:08 dan DAN-PC Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/DIRECTX.t...
2016/9/14:17:12:24 dan DAN-PC Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/DIRECTX.t...
2016/9/14:17:12:24 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:17:13:38 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:17:13:38 dan DAN-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/CM.tar.lz...
2016/9/14:17:14:11 dan DAN-PC Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/CM.tar.lz...
2016/9/14:17:14:11 dan DAN-PC Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/14:17:14:12 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:17:14:12 dan DAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/9/14:17:14:12 dan DAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/9/14:17:14:13 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:17:14:35 dan DAN-PC === Setup ended ===
2016/9/14:17:15:08 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:15:08 dan DAN-PC Path_Length: 154
2016/9/14:17:15:08 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2016/9/14:17:15:08 dan DAN-PC Launch
2016/9/14:17:15:08 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2016/9/14:17:15:08 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI7030.tmp
2016/9/14:17:15:19 dan DAN-PC === Setup ended ===
2016/9/14:17:15:12 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:15:12 dan DAN-PC Path_Length: 154
2016/9/14:17:15:12 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI7030.tmp
2016/9/14:17:15:12 dan DAN-PC Launch
2016/9/14:17:15:14 dan DAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2016/9/14:17:15:14 dan DAN-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2016/9/14:17:15:14 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI7030.tmp\Setup\AcSetup.dll
2016/9/14:17:15:14 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:17:15:14 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:15:24 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:15:24 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:17:15:24 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:15:41 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:17:15:41 dan DAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2016/9/14:17:15:41 dan DAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2016/9/14:17:15:41 dan DAN-PC Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/DIRECTX.t...
2016/9/14:17:15:41 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:17:16:27 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:17:16:27 dan DAN-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/CM.tar.lz...
2016/9/14:17:17:01 dan DAN-PC Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/CM.tar.lz...
2016/9/14:17:17:01 dan DAN-PC Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/14:17:17:01 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:17:17:02 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:17:17:11 dan DAN-PC === Setup ended ===
2016/9/14:17:18:14 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:18:14 dan DAN-PC Path_Length: 154
2016/9/14:17:18:14 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/14:17:18:14 dan DAN-PC Launch
2016/9/14:17:18:14 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/14:17:18:14 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI46FF.tmp
2016/9/14:17:20:39 dan DAN-PC === Setup ended ===
2016/9/14:17:18:17 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:18:17 dan DAN-PC Path_Length: 154
2016/9/14:17:18:17 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI46FF.tmp
2016/9/14:17:18:17 dan DAN-PC Launch
2016/9/14:17:18:19 dan DAN-PC Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/14:17:18:19 dan DAN-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/14:17:18:20 dan DAN-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/14:17:20:39 dan DAN-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/14:17:20:39 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI46FF.tmp\Setup\AcSetup.dll
2016/9/14:17:20:39 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:17:20:39 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:21:00 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:21:00 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:17:21:00 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:21:30 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:17:21:31 dan DAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:21:31 dan DAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:21:31 dan DAN-PC Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/14:17:21:40 dan DAN-PC Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/14:17:21:40 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:17:22:29 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:17:22:29 dan DAN-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:23:07 dan DAN-PC Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:23:07 dan DAN-PC Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/14:17:23:07 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:17:23:08 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:17:24:38 dan DAN-PC === Setup ended ===
2016/9/14:17:31:41 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:31:41 dan DAN-PC Path_Length: 154
2016/9/14:17:31:41 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI849B.tmp
2016/9/14:17:31:41 dan DAN-PC Launch
2016/9/14:17:31:43 dan DAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/14:17:31:43 dan DAN-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/14:17:31:43 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI849B.tmp\Setup\AcSetup.dll
2016/9/14:17:31:43 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:17:31:44 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:31:37 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:31:37 dan DAN-PC Path_Length: 154
2016/9/14:17:31:37 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/14:17:31:37 dan DAN-PC Launch
2016/9/14:17:31:37 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/14:17:31:37 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI849B.tmp
2016/9/14:17:32:06 dan DAN-PC === Setup ended ===
2016/9/14:17:31:57 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:31:57 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:32:18 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:32:18 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:32:35 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:32:35 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:17:32:35 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:35:30 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:17:35:30 dan DAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:35:30 dan DAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:35:30 dan DAN-PC Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/14:17:35:30 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:17:36:22 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:17:36:22 dan DAN-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:36:53 dan DAN-PC Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:36:53 dan DAN-PC Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/14:17:36:54 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:17:36:55 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:17:37:07 dan DAN-PC === Setup ended ===
2016/9/14:17:39:52 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:39:52 dan DAN-PC Path_Length: 154
2016/9/14:17:39:52 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/14:17:39:52 dan DAN-PC Launch
2016/9/14:17:39:52 dan DAN-PC CommandLine /PK 001H1 /SN 900-77218366 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/14:17:39:52 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AIC8F.tmp
2016/9/14:17:40:05 dan DAN-PC === Setup ended ===
2016/9/14:17:39:57 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:17:39:57 dan DAN-PC Path_Length: 154
2016/9/14:17:39:57 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AIC8F.tmp
2016/9/14:17:39:57 dan DAN-PC Launch
2016/9/14:17:40:00 dan DAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/14:17:40:00 dan DAN-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/14:17:40:01 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AIC8F.tmp\Setup\AcSetup.dll
2016/9/14:17:40:01 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:17:40:01 dan DAN-PC PageOpen LaunchDialog
2016/9/14:17:40:50 dan DAN-PC PageOpen LicenseDialog
2016/9/14:17:40:50 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:17:40:50 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:17:40:54 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:17:40:54 dan DAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:40:54 dan DAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/14:17:40:54 dan DAN-PC Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/14:17:40:54 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:17:41:51 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:17:41:51 dan DAN-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:42:57 dan DAN-PC Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/14:17:42:57 dan DAN-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/14:17:43:46 dan DAN-PC Install Autodesk Material Library 2016 Succeeded
2016/9/14:17:43:47 dan DAN-PC Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/14:17:45:25 dan DAN-PC Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/14:17:45:25 dan DAN-PC Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/14:17:45:48 dan DAN-PC Rollback Autodesk Material Library 2016 Succeeded
2016/9/14:17:45:48 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:17:45:49 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:17:55:38 dan DAN-PC === Setup ended ===
2016/9/14:18:06:57 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:18:06:57 dan DAN-PC Path_Length: 154
2016/9/14:18:06:57 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2016/9/14:18:06:57 dan DAN-PC Launch
2016/9/14:18:06:57 dan DAN-PC CommandLine /akamai /sid a1b3A000007q3QeQAI /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2016/9/14:18:06:57 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AICE75.tmp
2016/9/14:18:08:05 dan DAN-PC === Setup ended ===
2016/9/14:18:06:58 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:18:06:58 dan DAN-PC Path_Length: 154
2016/9/14:18:06:58 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AICE75.tmp
2016/9/14:18:06:58 dan DAN-PC Launch
2016/9/14:18:07:01 dan DAN-PC Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:07:01 dan DAN-PC Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:07:02 dan DAN-PC Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:08:04 dan DAN-PC Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:08:04 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AICE75.tmp\Setup\AcSetup.dll
2016/9/14:18:08:04 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:18:08:05 dan DAN-PC PageOpen LaunchDialog
2016/9/14:18:08:12 dan DAN-PC PageOpen LicenseDialog
2016/9/14:18:08:12 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:18:09:21 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:18:09:33 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:18:09:33 dan DAN-PC Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2016/9/14:18:09:33 dan DAN-PC Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2016/9/14:18:09:33 dan DAN-PC Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2016/9/14:18:09:41 dan DAN-PC Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2016/9/14:18:09:41 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:18:10:33 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:18:10:33 dan DAN-PC Download Play CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2016/9/14:18:11:01 dan DAN-PC Download Complete CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2016/9/14:18:11:01 dan DAN-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/14:18:11:41 dan DAN-PC Install Autodesk Material Library 2016 Succeeded
2016/9/14:18:11:42 dan DAN-PC Download Play CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:18:12:22 dan DAN-PC Download Aborted CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:18:12:22 dan DAN-PC Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/14:18:12:41 dan DAN-PC Rollback Autodesk Material Library 2016 Succeeded
2016/9/14:18:12:41 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:18:12:42 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:18:20:06 dan DAN-PC === Setup ended ===
2016/9/14:18:20:31 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:18:20:31 dan DAN-PC Path_Length: 154
2016/9/14:18:20:31 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2016/9/14:18:20:31 dan DAN-PC Launch
2016/9/14:18:20:31 dan DAN-PC CommandLine /akamai /sid a1b3A000007q3QeQAI /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2016/9/14:18:20:31 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI3948.tmp
2016/9/14:18:20:37 dan DAN-PC === Setup ended ===
2016/9/14:18:20:33 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:18:20:33 dan DAN-PC Path_Length: 154
2016/9/14:18:20:33 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI3948.tmp
2016/9/14:18:20:33 dan DAN-PC Launch
2016/9/14:18:20:34 dan DAN-PC Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:20:34 dan DAN-PC Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:18:20:35 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI3948.tmp\Setup\AcSetup.dll
2016/9/14:18:20:35 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:18:20:36 dan DAN-PC PageOpen LaunchDialog
2016/9/14:18:20:42 dan DAN-PC PageOpen LicenseDialog
2016/9/14:18:20:42 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:18:21:20 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:18:21:22 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:18:21:22 dan DAN-PC Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2016/9/14:18:21:23 dan DAN-PC Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2016/9/14:18:21:23 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:18:21:59 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:18:21:59 dan DAN-PC Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2016/9/14:18:21:59 dan DAN-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/14:18:22:22 dan DAN-PC Install Autodesk Material Library 2016 Succeeded
2016/9/14:18:22:22 dan DAN-PC Download Play CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:18:23:02 dan DAN-PC Download Aborted CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:18:23:02 dan DAN-PC Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/14:18:23:23 dan DAN-PC Rollback Autodesk Material Library 2016 Succeeded
2016/9/14:18:23:23 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:18:23:24 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:18:24:37 dan DAN-PC === Setup ended ===
2016/9/14:19:14:01 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:19:14:01 dan DAN-PC Path_Length: 154
2016/9/14:19:14:01 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2016/9/14:19:14:01 dan DAN-PC Launch
2016/9/14:19:14:01 dan DAN-PC CommandLine /akamai /sid a1b3A000007q44UQAQ /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2016/9/14:19:14:01 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI36BA.tmp
2016/9/14:19:14:09 dan DAN-PC === Setup ended ===
2016/9/14:19:14:03 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:19:14:03 dan DAN-PC Path_Length: 154
2016/9/14:19:14:03 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI36BA.tmp
2016/9/14:19:14:03 dan DAN-PC Launch
2016/9/14:19:14:06 dan DAN-PC Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:19:14:06 dan DAN-PC Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:19:14:06 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI36BA.tmp\Setup\AcSetup.dll
2016/9/14:19:14:06 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:19:14:08 dan DAN-PC PageOpen LaunchDialog
2016/9/14:19:14:32 dan DAN-PC PageOpen LicenseDialog
2016/9/14:19:14:32 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:19:15:18 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:19:17:44 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:19:17:44 dan DAN-PC Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2016/9/14:19:17:44 dan DAN-PC Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2016/9/14:19:17:44 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:19:18:17 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:19:18:17 dan DAN-PC Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2016/9/14:19:18:17 dan DAN-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/14:19:18:48 dan DAN-PC Install Autodesk Material Library 2016 Succeeded
2016/9/14:19:18:49 dan DAN-PC Download Play CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:19:19:37 dan DAN-PC Download Aborted CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:19:19:37 dan DAN-PC Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/14:19:20:00 dan DAN-PC Rollback Autodesk Material Library 2016 Succeeded
2016/9/14:19:20:00 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/14:19:20:01 dan DAN-PC PageOpen InstallCompleteDialog
2016/9/14:19:20:09 dan DAN-PC === Setup ended ===
2016/9/14:19:24:56 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:19:24:56 dan DAN-PC Path_Length: 154
2016/9/14:19:24:56 dan DAN-PC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2016/9/14:19:24:56 dan DAN-PC Launch
2016/9/14:19:24:56 dan DAN-PC CommandLine /akamai /sid a1b3A000007q490QAA /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2016/9/14:19:24:56 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI2B16.tmp
2016/9/14:19:25:04 dan DAN-PC === Setup ended ===
2016/9/14:19:24:59 dan DAN-PC === Setup started on DAN-PC by dan ===
2016/9/14:19:24:59 dan DAN-PC Path_Length: 154
2016/9/14:19:24:59 dan DAN-PC Current Directory C:\Users\dan\AppData\Local\Temp\_AI2B16.tmp
2016/9/14:19:24:59 dan DAN-PC Launch
2016/9/14:19:25:00 dan DAN-PC Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:19:25:00 dan DAN-PC Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2016/9/14:19:25:00 dan DAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\dan\AppData\Local\Temp\_AI2B16.tmp\Setup\AcSetup.dll
2016/9/14:19:25:00 dan DAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/14:19:25:02 dan DAN-PC PageOpen LaunchDialog
2016/9/14:19:25:56 dan DAN-PC PageOpen LicenseDialog
2016/9/14:19:25:56 dan DAN-PC PageOpen ProductInfoDialog
2016/9/14:19:27:19 dan DAN-PC PageOpen ProductSelectionDialog2
2016/9/14:19:27:22 dan DAN-PC PageOpen FullProgressDialog
2016/9/14:19:27:22 dan DAN-PC Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2016/9/14:19:27:23 dan DAN-PC Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2016/9/14:19:27:23 dan DAN-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/14:19:27:55 dan DAN-PC Install DirectX Runtime Succeeded
2016/9/14:19:27:55 dan DAN-PC Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2016/9/14:19:27:55 dan DAN-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/14:19:28:22 dan DAN-PC Install Autodesk Material Library 2016 Succeeded
2016/9/14:19:28:22 dan DAN-PC Download Play CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:19:29:22 dan DAN-PC Download Aborted CMILB http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB...
2016/9/14:19:29:22 dan DAN-PC Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/14:19:29:40 dan DAN-PC Rollback Autodesk Material Library 2016 Succeeded
2016/9/14:19:29:40 dan DAN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
