zionshea
en respuesta a: leothebuilder
Hello Leo,
I am working with the Model display.
Where do I set the display to "by material"? (In the Matterials tab under the Render Pannel, the Materials/Texture is set to "Materials/Textured on").
When I choose one of the already used materials, (i.e. Edit Object Display > Materials, then i use one of the materials from those that have been used before) the display is changed as expected.
BUT, as I said before, I cannot use any new material from the materials library.
Also, when I click one of the materials fom the Materials Library and drag it to the materials palette, the cursor is changed as expected (it used to work with Autocad 2010) and all looks OK but at the end no material is added to the Materials Palette.
Thanks for your help.
