3wood
en respuesta a: Anonymous
Here provide 2 methods to do it automatically.
Method 1
1. Trim around the boundary  with command EXTRIM (Express Tools)
2. Select all entities inside the boundary with SMARTSEL, then press Esc to cancel the selection.
3. Command ERASE -> ALL -> Remove -> Previouse -> Enter.
Method 2
1. Make a block from all entities except the boundary.
2. Clip the block with the boundary polyline. You can use CLIPIT command.
2. Explode the block with EXPLODEALL, settings as below:
