318 Vistas, 3 Respuestas
Publishing to pdf
I'm using AC Light 2007.
I'm trying to publish to pdf but when the screen comes up, the only choice I see is Publish to DWF. What do I need to do to change that so I can publish to pdf format?
Thank you.
pendean
en respuesta a: Anonymous
Did 2007 come with a built-in PDF driver? See one in PLOT command for example? Called DWG TO PDF.PC3 file if there is one.
en respuesta a: pendean
Yes, it came with DWG TO PDF pc3
Yes, It came with DWG TO PDF.PC3.
