en respuesta a: Anonymous
http://examples.activepdf.com/CADConverter/2015/CAD_to_PDF_conversion_with_settings.cs
I found this from this website called activepdf which does this. Is anyone familiar with this product.
/ Copyright (c) 2016 ActivePDF, Inc.
// ActivePDF CADConverter 2015
// Example created 05/03/16
using System;
// Make sure to add the ActivePDF product .NET DLL(s) to your application.
// .NET DLL(s) are typically found in the products 'bin' folder.
class Examples
public static void Example()
string cadXML;
string strPath;
DCDK.Results.DocConverterResult results;
strPath = System.AppDomain.CurrentDomain.BaseDirectory;
// Instantiate Object
APDocConverter.DocConverter oDC = new APDocConverter.DocConverter();
// Settings specific to CAD conversions
APDocConverter.CADConverter.CADConverter oCAD = new APDocConverter.CADConverter.CADConverter();
// Options available for CAD conversions
// Options that are 'NotSet' use the setting from the configuation manager
oCAD.ASCIIHexEncoding = false;
oCAD.Color = APDocConverter.CADConverter.ColorMode.NotSet;
oCAD.EmbedFonts = APDocConverter.CADConverter.EmbedFontsOptions.NotSet;
oCAD.ExportLayers = APDocConverter.CADConverter.LayersOptions.NotSet;
oCAD.ExportLayouts = APDocConverter.CADConverter.LayoutsOptions.NotSet;
oCAD.FlateCompression = false;
oCAD.HatchToBitmapDPI = 150;
oCAD.HiddenLineRemoval = false;
oCAD.Lineweight = APDocConverter.CADConverter.LineweightOptions.NotSet;
oCAD.OtherHatchesSettings = APDocConverter.CADConverter.OtherHatchOptions.NotSet;
oCAD.PlotStyleTableName = "";
oCAD.SHXTextAsGeometry = false;
oCAD.SimpleGeometryOptimization = false;
oCAD.SolidHatchesSettings = APDocConverter.CADConverter.SolidHatchOptions.NotSet;
oCAD.TrueTypeAsGeometry = false;
oCAD.ZoomToExtents = true;
// Page size is only set if ZoomToExtents is true
oCAD.SetExtentsPageSize(210, 297);
// Convert the settings to XML and send it to DocConverter
cadXML = oCAD.Serialize();
oDC.SetAddonOptions(cadXML);
oCAD = null;
// Set the amount of time before a request will time out
oDC.TimeoutSpan = new TimeSpan(0, 0, 40);
// Enable extra logging (logging should only be used while troubleshooting)
// C:\ProgramData\activePDF\Logs\
oDC.Debug = true;
// Convert the file to PDF
// If the output parameter is not used the created PDF will use
// the input string substituting the filename extension to 'pdf'
results = oDC.ConvertToPDF(strPath + "sample.dwg", strPath + "new.pdf");
if (results.DocConverterStatus != DCDK.Results.DocConverterStatus.Success)
ErrorHandler("ConvertToPDF", results, results.DocConverterStatus.ToString());
// Release Object
oDC = null;
// Process Complete
WriteResults("Done!");
// Error Handling
public static void ErrorHandler(string strMethod, ADK.Results.Result results, string errorStatus)
WriteResults("Error with " + strMethod);
WriteResults(errorStatus);
WriteResults(results.Details);
if (results.Origin.Function != strMethod)
WriteResults(results.Origin.Class + "." + results.Origin.Function);
if (results.ResultException != null)
// To view the stack trace on an exception uncomment the line below
//WriteResults(results.ResultException.StackTrace);
Environment.Exit(1);
// Write output data
public static void WriteResults(string content)
// Choose where to write out results
// Debug output
//System.Diagnostics.Debug.WriteLine("ActivePDF: * " + content);
// Console
Console.WriteLine(content);
// Log file
//using (System.IO.TextWriter writer = new System.IO.StreamWriter(System.AppDomain.CurrentDomain.BaseDirectory + "application.log", true))
// writer.WriteLine("[" + DateTime.Now.ToString("MM/dd/yyyy HH:mm:ss") + "]: => " + content);
