1069 Vistas, 1 Respuesta
The following shortcuts in the plotter search were invalid and ignored.
I keep on getting an error message when I try to print to the plotter  - The following shortcuts in the plotter search were invalid and ignored: *path to file on shared drive*
I've gone in and checked that all paths point to the correct paths but can't find out why this message keeps coming up.
Has anyone got any idea's that may help?
Kind Regards
Sam
pendean
en respuesta a: Anonymous
The error meesage is about invalid shortcut files I believe, you know, file names with an image of an arrow in them that Windows Explorer identifies as "shortcuts".
You use a shared drive? Is it unplugged or in sleepmode perhaps?
Start in the folder listed in OPTIONS command's FILES Tab, Printer Support File Path section, all four subsections, is probably were the shortcuts are that need addressing.
