01-25-2017
06:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-25-2017
06:12 AM
What is your final intent with this image? Explain, there might be better solutions. I suspect you probably ought to be publishing to PDF instead as I look at your posted image.
BTW The name of the driver is PUBLISH TO WEB: web picture publishing resolution is about as low as you can go. Did you know that?
Try and change the output settings before you use that plotter again and see if you get better results. Same with Tiff and EPS drivers you may have. Looks like you are trying to print to a tabloid size paper size.
Also explore JPGOUT or PNGOUT commands after you set RASTERDPI to something more desirable than the default setting.
