Richard.Vivanco
en respuesta a: Anonymous
Hi
Your project was drawed in real dimensions? 1cm in the model space is equivalent with 1 cm in your object?  Or you input 0.01  when you draw 1cm?
Use your distance command and verify this, if you have this problem you need to scale the objects by 100
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
