560 Vistas, 4 Respuestas
need help with 3d print and autocad
i designed something in autocad (changed measurements with using"units" command and choosen centimeters)
after designing i selected the object and then exported as .stl file
and then i loaded that file in repetier host, but now in the repetier host my object is too small and shows 14 mm filament will be needed for print.
can you tell me what's wrong? so i can fix it and use my first new 3d printer its Flsun 3d printer metal frame one.
bed size in repetier host is 200 mm x 200 mm
