564 Vistas, 4 Respuestas
need help with 3d print and autocad
i designed something in autocad (changed measurements with using"units" command and choosen centimeters)
after designing i selected the object and then exported as .stl file
and then i loaded that file in repetier host, but now in the repetier host my object is too small and shows 14 mm filament will be needed for print.
can you tell me what's wrong? so i can fix it and use my first new 3d printer its Flsun 3d printer metal frame one.
bed size in repetier host is 200 mm x 200 mm
Richard.Vivanco
en respuesta a: Anonymous
Hi
Your project was drawed in real dimensions? 1cm in the model space is equivalent with 1 cm in your object?  Or you input 0.01  when you draw 1cm?
Use your distance command and verify this, if you have this problem you need to scale the objects by 100
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Emmsleys
would be able to share a sample file? I can try testing it on my end?
Sarah Emmsley
Technical Support Specialist
Emmsleys
Following up were you able to find a solution or a suitable workaround?
Post back with any new updates.
Sarah Emmsley
en respuesta a: Emmsleys
Sorry for such untimely response!  Company switched to MicroStation immediately after I posted. please accept my apologies all. I don't have the issue right now, but if I do i'll be back!
