219 Vistas, 1 Respuesta
11-16-2016
07:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-16-2016
07:26 AM
Rotate 3D in 2004
Hi. I am relatively new to using 3D functions in AutoCAD, 99.9% of what I do is in 2d. I received a file (attached) with 6 flat planes. The problem is, they are vertical, so when you go to a top view, all you see is the edge. I need to rotate them so that you see the flat plane. Note - one of them isn't completely flat, I will have to treat that separately I think.
Anyway, when I use the rotate command, all I can figure out how to do is to spin them around, I can't seem to rotate them so that the flat part faces up. Is there a way to do this in 2004? Thanks in advance.
