rkmcswain
en respuesta a: Anonymous
List the objects.
The red polyline has an extrusion direction or -1 in the Z axis.
LWPOLYLINE  Layer: "Level 41"
                            Space: Model space
                   Color: 1 (red)    Linetype: "BYBLOCK"
                   LineWeight: 0.40 mm
                   Handle = 2f0
              Open
    Constant width    0.0000
Extrusion direction relative to UCS:
                   X=   0.0000  Y=   0.0000  Z=  -1.0000
              area   709.5730
            length   278.9087
          at point  X=350360.9444  Y=2637496.2227  Z=   0.0000
             bulge    0.0274
            center  X=347815.1196  Y=2637555.8389  Z=   0.0000
            radius 2546.5227
       start angle       181
         end angle       188
          at point  X=350339.1736  Y=2637218.3047  Z=   0.0000
The JOIN command (AutoCAD 2006+) will join these two, but the result is a SPLINE
I'd say it's better to fix the red polyline, then join them as a single polyline.
