Alfred.NESWADBA
en respuesta a: Anonymous
welcome @Anonymous.autodesk.com!
>> The program only working when granted admistrator right
I guess the diagnostic is where you should start. When admin permissions are needed then the only thing you have to search is which files or registry contents are blocked when you run AutoCAD in "normal user" mode.
One tool you can use for that is ProcessMonitor (>>>click<<<), here you can list all file and registry actions, which are blocked or ok.
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
