02-27-2016
10:28 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-27-2016
10:28 PM
there are more than just one possibility, most likely the color type of the image, if it's
- bitonal (that is just a black/white image) ... this is the easiest way to get the background of an image transparent in AutoCAD
- 8bit or 24bit image, then a real white might be used to be transparent (depends also on the version of AutoCAD you have
- 32bit image, so the image contains an alpha channel, but don't know if the scanner see's white as transparent.
First try to save the image as bitonal (or "blacl/white") ... if the scanner software can't do that you can use some free software like IrfanView to convert your image to black/white. If that does not work then please
- let us know your AutoCAD version number
- scan some linework (not your signature
) and upload this image so we know what your scanner ships as data and we can give tips how to do with your raster files.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
