384 Vistas, 4 Respuestas
Markup republish creates DWF inside of unexpected directory
AutoCAD 2009 SP3 x64 Enu.
When my user for the Markup Set Manager launches the "Markup republish" operation then the result doesn't rewrite current DWF file (which is republishing), but it creates the new DWF file in the other, unexpected by user directory. The output result is displaying on the Plot and Publish Details window.
But we expect either the source DWF will be rewritten, or the name of the output file name will be asked.
Why does it happen? How can I fix it?
Best regards, Andrey
Etiquetas (3)
wispoxy
en respuesta a: Anonymous
@Anonymous What driver are you using to publish?
en respuesta a: wispoxy
@wispoxy, what do you mean? I do it through the Markup Set Manager context menu. I know nothing about the "driver". Both DWF files are located in the domain network.
wispoxy
When you PUBLISH, what are you publishing with? Name of .PC3 or Adobe
We use PC3 by Autodesk.
