- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I want to add an image (jpg) to autocad and draw on it some additions then have the whole thing back again as an image.
How can I do that on autocad 2007
Thanks in advance
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm curious more than anything: is HELP broken in R2007 on your PC? I ask because you could have just as easily looked it up, or even Google Search the answer in this the year 2017.
Hint to the answer you seek:
IMAGEATTACH command (if R2007 has it)
or IMAGE command
or drag-drop from Windows Explorer onto your open DWG file are a few of the options to try.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the process of display the image in AutoCAD is discussed.
But for that:
You can't directly modify the original image, as long as you don't have RasterDesign as add-on for AutoCAD.
So the option to get an image as result can be a result of plotting to a raster-file (or with reduced quality by doing a screenshot.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Did any of the posts in the thread help with you issue?
To add you can also take a look at the following:
Sarah Emmsley
Technical Support Specialist
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please post back in the thread if you are still having an issue with AutoCAD.
Sarah Emmsley
