Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
When using the Draw Points/ divide feature. The points that are laid out on the line are not recognized by the Object Snap function.  It is like they are not regular lines.  Is there a way to get them to be recognized by the OSNAP?
Welcome to these Forums!
That's because they're not, in fact, Lines -- a Point is a different entity type altogether.  The NODE Osnap mode [or just the 3-letter abbreviation NOD if you want to save a keystroke] will snap to them.  If you are seeing them as more than tiny dots because of a PDMODE setting, and they look like crosses or X's or little circles or some combination, Node Osnap will snap to the Point [tiny dot] location itself, not to what look like lines and/or circles making up the on-screen appearance of them.
Kent Cooper, AIA
