15 Kudos
24 Solutions
2014 New Synonym feature??? PGP file?
662 Views, 7 Replies
04-30-2013 08:16 AM
Isn't the new Synomym feature the same as PGP file?
Discussion?
AUTODESK EXPERT ELITE
816 Kudos
604 Solutions
Re: 2014 New Synonym feature??? PGP file?
04-30-2013 09:24 AM in reply to: mdhutchinson
In AutoCAD 2014 for Windows synonyms are storied in acadSynonymsGlobalDB.pgp file.
In AC for Mac since 2011 - they are inside acad.pgp file:
So I think synonyms are "extended" aliases for "easy of use".
Maxim
Architect
MARSS
MacACAD | MARSS
15 Kudos
24 Solutions
05-02-2013 08:55 AM in reply to: maxim_k
so... for Windows, has acadSynonymsGlobalDB.pgp replaced Acad.pgp?
Does Acad.pgp still exist?  The shell commands are there...
What is so 'Global' about acadSynonymsGlobalDB.pgp... ?
What sense does it make to have, and maintain, both of these?
2817 Kudos
2296 Solutions
05-02-2013 09:02 AM in reply to: mdhutchinson
Two separate animals: acad.pgp still has the same exact function.
The newer function is that 2014 feature being touted where it tries to guess what you mean when you type something unique like DRAW (it will start Line command). Leave the newer pgp file alone and don;t mix/match functionaility unless you honestly did have DRAW defined as LINE command for some inexplicable reason instead of just L Smiley Happy
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
816 Kudos
604 Solutions
05-02-2013 09:03 AM in reply to: mdhutchinson
acad,pgp is still here.
No ideas about "Global"
Maxim
Architect
MARSS
MacACAD | MARSS
812 Kudos
291 Solutions
06-19-2013 05:33 AM in reply to: mdhutchinson
You now also have a AutoCorrectUserDB.pgp in 2014. That stores frequent misspellings that the program figures out as you type and then select from the suggestions offered. You can also add your own.
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
877 Kudos
367 Solutions
06-19-2013 05:46 AM in reply to: mdhutchinson
Discussion?
Essentially, Yes.
Neither of the new "pgp" files needed creating IMO.
I wrote an article on this recently ( http://bit.ly/161M9iv ) that goes into more detail.
R.K. McSwain     | CADpanacea | twitter | My Screencasts
812 Kudos
291 Solutions
06-19-2013 05:57 AM in reply to: mdhutchinson
I just got an idea on how to use the new pgp files to my advantage. Not the way it was intended of course!
I have purchased a 3rd party add-on to make my life easier. The rest of the users don't have it. So if I add the aliases that are provided with it. I might cause problems for other users since the acad.pgp file is shared on the network.
I could add those aliased to the AutoCorrectUserDB.pgp and keep it local. A corrections file should be kept locally anyway. Maybe that way I can eat my cake and have it too.
Allen Jessup
Allen Jessup
