1665 Vistas, 12 Respuestas
Prefix Sheet Titles with File Names Greyed Out
The option to prefix sheet titles with file names when importing dwgs to SSM is greyed out. I need to move a project to a new location on our server and was hoping I could just import existing dwgs back into the new ssm project but all my sheet title names are my Layout tab name. The option to use file names for the sheet title names is greyed out. SSM should give the option to name the sheet as they were named in the previous .dst file. Seems I'm now forced to import and then rename each sheet. I have a couple hundred sheets....there goes my day.
en respuesta a: Anonymous
Were you ever able to solve this issue? We are running into the same problem. Thanks!
CADmgrMike
I'm noticing this in C3D 2021, but it was fine in our 2019. Must be a setting somewhere???
Mike Porter
https://provostandpritchard.com/
CADmgrMike
I'm also seeing that it works in my AutoCAD 2021 but not in C3D 2021.
Mike Porter
pendean
en respuesta a: CADmgrMike
@CADmgrMike The dedicated C3D forums are over here https://forums.autodesk.com/t5/civil-3d/ct-p/4003
CADmgrMike
This isn't a C3D issue. I found the fix here: Solved: Import Layouts as Sheets - Autodesk Community - AutoCAD
Mike Porter
sazevedoD2J44
Did anyone solve this? Mine is greyed out in 2024 CAD and still can't solve the problem.
pendean
en respuesta a: sazevedoD2J44
Can you show us in a screenshot or three what and where it is "grayed out" please?
And confirm if this applies to all of your sheetsets or just this one, and what if anything is different about it?
sazevedoD2J44
en respuesta a: pendean
It applies to all sheets.
pendean
Which variant and year version of AutoCAD are you using?
In your screenshot you have no (zero) drawings or layouts chosen yet: does that box become selectable when there is a list of layouts in that table?
sazevedoD2J44
I'm using 2024 AutoCAD. It doesn't matter how many drawings I select. It still stays greyed out.
pendean
Is your SheetSet DST file locked or open by others or....?
I am unable to replicate your issue here in our own SheetSets in 2023-2024-2025, so I'm not sure how to address your uncheck-able box
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
sazevedoD2J44
 Still greyed out after I try importing a sheet.
