en respuesta a: Anonymous
Even if we are in isometric mode, it is always possible to draw normal ellipses, for which we need to select "arc" or "center" option. Isocircles would be drawn only if we select "isocircle" option (which is available only in isometric mode). Therefore, if AutoCAD is not allowing to select "isocircle" option in "center" method of drawing ellipse, but does allow in the "axis, end" method, it can only be termed a bug in the software.
Even the "elliptical arc" method allows selection of "isocircle" option. Thus, out of three available methods, two are allowing and one is not allowing (even though it does display this option). Moreover, an isocircle is drawn with reference to a specified center only. And, the center method does not work. If defies all logic. Let us accept that AutoCAD has missed or messed this point. This might have been corrected in recent versions which I am not aware of.
