716 Vistas, 3 Respuestas
AEC Wall disapears in xref inside a block - only fix so far is exploding it
We have a file I am working on with another colleague, and whenever she uses the file, the AEC walls disappear in an xreffed file which is also inside a block. We both have the same autocad. The only fix I've found so far is to explode the block every time one of us reopens the file which fixes the AEC walls throughout all the blocks. I'm looking for a permanent solution. Any help would be appreciated. Thanks!
