- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Does basic(?) Autocad 2010 include Autocad 2010 Electrical or is Autocad 2010 Electrical a stand-alone download? Or, can the Electrical be integrated with the basic(?) Autocad 2010? Much Thanks, CNM.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, AutoCAD Electrical is a stand-alone.
Basic AutoCAD does not include AutoCAD Electrical. AutoCAD Electrical has more than AutoCAD, It's basically AutoCAD with Electrical Tools. Notice the price difference in the following link: http://www.autodesk.com/products/autocad-electrical/compare-products
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
physical layout in a panel along with physical dimensioning? Thanks, CNM.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
2010 and AutoCAD Electrical 2015 or are they basically the same? Much
Thanks, CNM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here is a list for Autocad 2011-2015, for Electrical Specifically I do not know. This list still applies to AutoCAD Electrical 2015 because remember what I said earlier, it's AutoCAD with electrical tools. Check out my full list that I just posted >HERE<
2011
- Grid - lines in 2D
- Ribbon updates, added 3D Basic WS
- Grip added to polyline
- Selection cycling enhancement - SC toggle at bottom of screen
- Multifunctional grips
- SelectSimilar command added, HideObjects, Unhide,
- AddSelected command added
- HideObjects command added
- IsolateObjects, UnisolateObjects
- 3D object snaps
2012
- Autocomplete command
- VpControl viewport controls - navigation, views and visual styles on screen
- Ribbon sizing - three minimized settings
- mtext background remembers last used fill color and offset
- grip with lengthen option
- grips are multi-functional for more objects - arcs, assoc arrays, dims, elliptical arcs, lines, mleaders, 3d faces edges vertices
- Associative Arrays, grips editing
- Blend - connects two objects using a spline
- Extend works with Splines, Fillet works with Splines
- Support for multiple paths for PMP, PC3, CTB, STB files
- Snap can be set to work only while in a command, SnapMode sysvar
- Drawing Views - 2D drawing views from 3D model and 1st or 3rd angle projection Base View
- 3D editing - ChamferEdge and FilletEdge added Loop option
- 3D editing - OffsetEdge
- MeshCap has options added
- Point Clouds enhanced
2013
- drawing views additions, create details and sections
- Properties - shows realtime previews for colors, lineweights, lintypes, transparency, layers
- Array - displays contextual tab, uses default values to show instant previews
- Offset has preview before picking
- Polylines - reversed plines with varying widths handled with new sysvar PlineReverseWidths
2014
- command line - spell checking, synonyms, block names, layer names, hatch name, visual styles, dim style
- autocorrect - after three misspellings the word is added
- type at command line to change layer, text style, dim style, visual style
- type at command line with hatch name to start hatch command
- type at the command line with a block name and the insert command will start
- mid string search at command line
- Drawing Tabs - tabs displayed for each drawing
- Chamfer command closes polylines
- Filleting polylines will close polylines
- Layers - merge selected layers in layer manager (LAYERDLGMODE must equal 1)
- Xref layer names are not shown in the properties palette
- Xrefs can be selected in quantities and the path or xref type changed in-mass
2015
- User interaction - Start, Help Find tool, Dark theme, Ribbon gallery, Improved graphics, Lasso selection, Command preview, Resizable modelspace viewports
- Design - Point cloud manager, Cropping, and object snaps, 3D Orbit Target
- Documentation - Autobullets and numbering, Mtext match properties, Mtext superscript and sibscript tools, Caps lock detection
- Connectivity - Design feed with local drawing storage, Autodesk translation framework
- Customization - BIM 360 add-in, Autodesk Application Manager, Performance reporting
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
Last question - are there any major differences between AutoCAD Electrical
Do you already have these products (can't generally purchase or license old releases)?
For physical 3D layouts (not schematics) you might also look at Autodesk Inventor Professional - Routed Systems.
