en respuesta a: Alfred.NESWADBA
Looks like I finally found the culprit.... now just to figure out how to fix it...
I reinstated the original "out-of-the-box" profile.  Since we run CadWorx and CadWorx Equipment through AutoCad, we have to add those support paths into the "Support File Search Path" of the "Files" portion of the "Options" dialogue box.  I can add the CadWorx path (C:\CADWorx 2015\Plant\Support) without problems but as soon as I add the CadWorx Equipment path (C:\CADWorx 2015\Equipment\Support), my "Copy to Clipboard Failed" errror returns.  I remove that path and restart, it goes away.  If I run CadWorx Equipment as a separate entity, all is good as well.
For now I will just run the two programs separate but in the meantime I'll continue to try and figure out why these errors are happening.  I'm thinking something in my Registry??
Christine
