- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> still receiving the "Copy to Clipboard Failed"
As long as there are Civil 3D objects in the drawing you can't copy such objects. The objects enabler just helps for some display issues, but does not let you create new objects. And copying a Civil3D object means "create a new one with the settings of the existing one ... and that (with that types of objects) can only work when you do have Civil 3D.
>> -EXPORTTOAUTOCAD didn't actually create any new files
Have you got any error message? If not I'm quite sure the file was created. When you where asked for the filename within the export command make sure to enter a valid folder- and filename and then - after the command finished - look to that folder.
If you get an error message, then please let us know which one.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
