Alfred.NESWADBA
en respuesta a: Anonymous
>> I've tried the last ditch fix of -EXPORTTOAUTOCAD to rid my drawing of these proxy objects
>> but they still don't go away.  Once I run that, I still get the errors shown in the image below
First at all: the dialog is not an error dialog, it gives you the information that there are proxy objects in the drawing, and from which applications they were created. But nothing of that is an error message.
Interesting is that you wrote that you run -EXPORTTOAUTOCAD, but the proxies stay in that drawing, that is strange and makes me more thinking that you created a new drawing with that command, but opened again the old one. Please notice that -EXPORTTOAUTOCAD creates a new drawing, in most cases with a leading "ACAD-" prefix in the filename.
As a sample if your drawing was called "GEODASY.DWG" the exported drawing will be named "ACAD-GEODASY.DWG" ... and that is the drawing you should use then to continue your work and that drawing should not show any proxy-informations (at least not the ones from Civil 3D.
Can you please verify that you opened the new file?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
