martecadlt
1175 Vistas, 2 Respuestas
Autocad 2011 - file path in the title bar
Hello
I use Autocad 2011 full with Windows 10 pro 64 bit.
The address bar does not display the name and the path of file if Autocad is open in full screen mode
How can I fix?
pendean
en respuesta a: martecadlt
LT2011 is not supported in Win10. No one is fixing anything forever sadly.
Otherwise File Path display is a selection you need to turn in OPTIONS command Open&Save Tab.
martecadlt
en respuesta a: pendean
thank you
but unfortunately that does not work
It seems to be a problem on Windows 10
