mark_renau
409 Vistas, 1 Respuesta
Problem with horizontal text and broken up text in a Vertical dimension ?
It's probably best to just look at the attached image of the drawing. I have tried matching properties from a correctly shown text beside the text with issues and it still does not fix the problem.  It's dimensions with fractions as well as whole numbers as you can see in the image.  Any ideas to resolve the issue?  The text in the drawing is shown correctly until you create a DWF or print the file and then you see the issues here and there in the drawing. Any help would be greatly appreciated.
Thank you for your time,
Mark R.
