04-23-2016
05:43 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-23-2016
05:43 AM
what I can see from your drawing content: using polylines for all the closed contours would be the better choice then single arcs and lines.
And when you say
>> Exporting from CAD to PDF
the better choice would be to use layout for plotting (a title block is nothing that should be placed on the modelspace) and instead of exporting the drawing use command _PLOT and use the "DWG to PDF.pc3" as plotter-setting.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
