04-09-2016
06:14 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-09-2016
06:14 AM
the first message tells you that this DWG file was produced on a none-Autodesk product.
It's a warning, not an error. Just run _AUDIT to make sure that the internal drawing database is ok.
The second messages gives you the info, that AutoCAD tries to load a tool (in that case ACADDOC.LSP) from a folder that is not marked as a trusted folder. And to prevent that AutoCAD then loads a virus it gives you that warning with the question if you want to load it or not.
I would not load a file ACADDOC.LSP from a download folder as long as I don't know who created that file and if I can trust it more than 100%.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
