- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
HOW TO USE THE AECTOACAD COMMAND?
hi there
i try to use this bcoz of FOREIGN DWG FILE and i read that AECTOACAD works for this
bu i dont know how to use it
i also attached the DWG file
please help me to check it
thank you very much and i hope for anyone to answer this
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Forgive me, but what problem are you trying to solve exactly? "foriegn dwg file" means little as I look at your file, other than the fact that it appears your dimensions are all messed up because someone moved the model but forgot to turn on that layer first
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
im sorry i forgot to attached the other file
Please check the FOREIGN DWG FILE and SECURITY CONCERN
thanks very much
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the first message tells you that this DWG file was produced on a none-Autodesk product.
It's a warning, not an error. Just run _AUDIT to make sure that the internal drawing database is ok.
The second messages gives you the info, that AutoCAD tries to load a tool (in that case ACADDOC.LSP) from a folder that is not marked as a trusted folder. And to prevent that AutoCAD then loads a virus it gives you that warning with the question if you want to load it or not.
I would not load a file ACADDOC.LSP from a download folder as long as I don't know who created that file and if I can trust it more than 100%.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
about security concern
i remove now
i just use OP comman then FILES tab then check TRUSTED LOCATION then specify the location of files only through browsing the folder
thanks anyway
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
just one warning from my side: a downloads folder is imho always a critical folder for the first place of a virus.
So please think about that decision to add the downloads folder to the trusted paths!
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i will not do adding the folder for this is virus ^^,
thanks
